The attached LabVIEW 8.5 vi demonstrates a problem I noticed using multicolumn listboxes. Upon changing the value (selected row) of the listbox programmatically, the very next press of the up or down arrow key behaves as if the value was never changed. For example, if the 3rd row is selected and then the listbox value is changed programmatically via a local variable or the value property to select the 0th row, pressing the down arrow key should now select the 1st row, but instead the 4th row is selected.
A workaround is to handle the Key Down? event myself as I've demonstrated in the attachment, but if this is a bug, I hope it can be corrected in a future release.
Larry
