06-03-2017 11:00 AM
Hello everyone.
I have attached two VIs. The functionality of both VIs is somewhat same, however, in the VI counter_edited.VI as I press the Boolean button, the counter register registers 255 in a single scan (unsigned byte). As far as I can think, it's because, in the single click of Boolean button, the program scans enough times to count 255 in the register. (I can rectify this using a time delay of 1 sec in the while loop) But, in another VI counter.VI, the signal to decision maker is fed through a comparison function. In this case, the counter counts 1 at a time with respect to the Boolean switch press.
Can I know why the difference in two VIs?
Thanks.
06-03-2017 11:17 AM
06-03-2017 11:36 AM
Thanks for the reply cbuthcer.
Can you please explain how additional check is implemented in the first VI to prevent multiple counts?
06-03-2017 12:47 PM
I have several comments about the two VIs you posted to use a push button to step through a loop on each push.
06-03-2017 01:19 PM
Hello Bob.
06-03-2017 04:52 PM
Shift Registers store values. After you run the code once, values are still stored in the Shift Register. Is there a value you want to put into the Shift Register when your program starts? Maybe 0? How would you think you initialize the Shift Register with a 0? Try your idea and see if it works.
06-03-2017 07:49 PM
Ganny wrote:
- Regarding this point, I get what you mean. This sample code Counter.VI I got this sample code from one of the videos from NI. I didn't feel there was necessity to compare two Boolean value. TBH, when I first coded it, I was not sure if it's going to work at all. That is why I modified the code and ended up with this doubt. Can you explain me why the "Count Register" doesn't get the value 255 just like in Counter_edited.VI even when the mechanical action for Boolean switch is Latch Until Released?
In Counter.vi, on the first iteration of the loop after you push the mouse button down on the button, the value that comes out of the DI terminal on the block diagram is true. The value coming from the shift register is false, from the previous iteration. As Bob explained, LabVIEW considers True > False, so the result of the comparison is true. This is passed to the shift register.
On the next iteration, your mouse is still held down. The value from DI is true, but the value from the shift register is also true. Therefore, the comparison is false (True == True, not True > True).
In the edited VI, there is no similar check, and so the VI climbs through the values incredibly quickly. There are a great many solutions to this, the simplest of which is to change the mechanical action as you have already discovered. Adding a Wait will seem like it solves the issue, but if you held the mouse down long enough, it would still count multiple times.
06-04-2017 03:43 AM - edited 06-04-2017 03:44 AM
Hello cbutcher,
Thanks for the explanation. I'm pretty much clear with the concept now. Can you explain me how to reset the counter when I stop the execution. i.e., if I restart the execution, counter should start from zero again.
06-04-2017 03:50 AM
Hi Ganny,
Glad to hear you're gaining understanding of the setup. As Bob Schor wrote (paraphrasing wildly) what you currently have is called an 'uninitialized shift register'. That is, you don't specify the value the Shift Register should start with. This is very useful in some situations, but not at all useful in others.
Fortunately, there's a simple solution - just initialize it! Essentially, the shift register holds values through the iterations of the loop. It has two additional connections to outside of the loop. One can be used as an output, taking the last value of the wire from the loop. The other is an input - it specifies the first value. When it isn't wired, the first value is the same as the last value from the previous time the VI ran.
See if you can guess which area you need to wire a 0 constant value to!
06-04-2017 12:49 PM
And, if you have never run it, it takes the "Default value" of whatever is contained in the Shift Register. For numerics, the Default Value is zero. For Booleans, it is "False". For Strings, it is an empty String. For Arrays, it is an empty Array.
A recent post (last 10 days) was generating an Array inside the loop and trying to sum the Arrays in a Shift Register. Because the Shift Register was not initialized, it took on the default "Empty Array" value, and because Arrays being added are only as large as the smaller Array, the sums were all Empty Arrays! Initializing the Shift Register to a proper-sized Array of zeros fixed this problem.
