07-02-2013 06:53 AM
I have LabView 2012 on the win XP 32bit and my program goes. But I move program to win Vista 64bit (program 32bit) and program execute only when I click on hightlight execution and immediately click to turn of hightlight. When I run a subvi in the program, this one execute right, but in the whole program not execute and still waiting for the answer from "Visa Write". The answer will not come at all.
Also I tried build application (exe), but the same problem.
May be is problem with migrate between 32bit and 64bit system or with win Vista, but I don't know.
I'll be glad for any help and advice.
Michal
07-02-2013 09:35 AM
Michal
I think you've confused yourself. The problem is more likely to be because your VISA resources (NOT Vista) are not set up the same from one computer to the other.
07-02-2013 10:46 AM
Thank you for your answer.
VISA set up correctly. SubVi work right separately. I have problem, when I insert this SubVi into whole program.
Michal
07-02-2013 10:51 AM
Post your VI's. It must be something about the way you are trying to use the subVI.
07-02-2013 12:20 PM
I'll post VI next week.
