03-06-2009 12:34 PM
Hey All,
How can I progmatically change the visible area of the x-scale on a Waveform Chart?
I want to be able to say enter in a number, like 50 and see the display update to display 0-50, however, once it hits 50 I want it to either update based on Sweep Chart settings, Scope Chart etc...
I can set the scope of the x-scale, like 0-50 using the x-scale range min and max property nodes, but it doesn't update continuously. And I also don't like the way you can do it using the graph palette property. Although this is the functionality I would like to mimic.
Any ideas?
Brad
03-06-2009 08:08 PM
Hey Brad,
Is this what you had in mind?
03-09-2009 07:18 AM
Yes, thanks for your help I figured out what I was doing wrong in the process.
Brad
