I am having this at the moment in Code it is working fine (Machine is running and controlled from the CAN)However I was thinking of reading the user numeric inputs also in the main loop (Top loop) and then send the values to the Timed loop for the CAN but so far the Producer Consumer method and Queue are to clever for me as I als ways end up with the same 100mSec loop time of the main loop
I am just feeling what I have at the moment is far from correct and that is what I am trying to find out or find the better /correct methods
--------------------------------------------------------------------------------------- Learning is an endless process but needs to start some where
