Producer Consumer Error
Having recently moved nearer to Baltimore, I may also become a Ravens Fan (with whom I frequently agree).  My solution to the "Double-Wire Bend" problem is not to bend the wires inside the function so they come out of the left and right corner connectors running up and down, but to move the function to straighten out as many bends as possible (see third example).  Yes, it's "only Style", but as Peter Blume points out in his excellent "The LabVIEW Style Book", good Style can make the difference between a Block Diagram whose meaning "jumps off the page" and is easily understood and one that requires several hours of study, with the VI in hand to "play with", to grasp.  [And hence a reason to ask to have VIs posted to the Forum instead of pictures of VIs ...].
Message 11 of 12
(386 Views)
Accepted by topic author Miller37
It turns out that there was an extra tunnel node that was causing my error. Once it was removed, the errors were resolved.
Thank  you for all the style inputs. I am now working to improve the style of my code.
Message 12 of 12
(361 Views)
