Ivan Dams wrote in message <847o7p$192$1@newnews1.news.nl.uu.net>...
>Everything works allright as long as use in the different vi´s only read or
>write datasockets like you also have
>in the examples of labview but when I try to combine those things , meaning
>writing and reading in one VI, I always get messages like can not create
>this item
From the DataSocket FAQ:
"You also need to create that item as a default item on the server, or allow
the other machine permission to create items. By default, every machine is
allowed to read data items, but only the localhost is allowed to create
items."
> , or can not set data because item is read only.
You are using a Write VI on a connection opened in Read (or ReadAutoUpdate)
mode.
In addition to the FAQ, there's lots mor
e information on DataSocket
available on the National Instruments web site at www.ni.com/datasocket.
Evan Cone
