Problems with the two Elapsed Time vi
Something like this should get you started. It assumes that you know how to use state machine, Shift registers, Data flow, Type Defs, Producer and consumer loops, Arrays, Event Structures.
If you don't know how to use all of these things you need to learn or editing this code will be very hard. If you do learn all of this it will be very easy.
This code can get more simple than this. I was trying to keep it simple so that you may be able to follow it.
Tim
GHSP
Message 11 of 17
(1,900 Views)
I am just looking to log the sample for the 5 second read, and no need for averaging.
Message 12 of 17
(1,899 Views)
Hi Tim,
Thanks a lot for your help.
Would you please attach your original vi  here, so I can learn from your vi as an example?
Your vi is more complex than I expected. I am not familiar with  state machine and consumer loops.  Thank you very much!
Message 13 of 17
(1,872 Views)
That is a VI snippet.  Save the picture to your hard drive.  Then drag the image file onto your block diagram.  Then you should have code in a new VI.
Message 14 of 17
(1,869 Views)
Thank you for your help. Following your suggestion, I have tried but not succeed. Is this  snippet only compatible with LabView2017? I am using a LabView 2012. Is there any method to  obtain the corresponding Vi? Could you please attach an orignal Vi here? Thank you again for your help.
Message 15 of 17
(1,846 Views)
Yes.  LV12 is too old to open an LV17 snippet.
I saved the snippet, brought it into a VI, then back saved the VI to LV12.
It will be broken because it has a typedef for the statemachine enum.  But you can disconnect from typedef.  Then save that enum as a new typedef control.  And change all the other instances to your newly saved control.
Message 16 of 17
(1,824 Views)
Thank you so much for your help. This Vi is very helpful.
Message 17 of 17
(1,816 Views)
