06-25-2008 04:04 AM
06-25-2008 10:02 AM
Hi Michael,
i get no error if i activate only one channel. You can also use only one "Physical Channel" control to select more than one channel, use the "durchsuchen" option to select one or more channels.
Hope it helps.
Mike
06-26-2008 02:57 AM
06-26-2008 05:51 AM
Hi Michael,
the error code you attach says something about calibration information. As i said before, i get no error with only one selected channel. The content help says, that you can transfer one or more waveforms to one task with analog outputs.
Mike
