Problems with calling a LV created DLL from C++
Hi there,
I tearing my hair out (well what reamins of it anyway) trying to get Microsoft Visual C++ to successfully call a function in a dll I created in LV. To illustrate the problem I've been trying to get the problem as simple as possible, I've now got it down to a VI which just assigns a constant to an indicator. This is then built into a DLL by the application builder.
The LV generated header for the Constant function looks like:
void Constant(double *Numeric, double *Numeric2)
I then copy the .h file, the .dll file and the .lib into the directory with my c++ files in, add the .h file and the .lib files to the c++ project and then call in my C++ routine like:
double N1; double N2;
Constant(&N1, &N2);
The c++ compiles and links ok but the value of N1 and N2 doesn't change from their un-initialized condition.
I can call the function ok from within labview using the call_dll vi and get back a result as expected.
Any ideas what I'm doing wrong ?
I'm using Microsoft Visual C++ Express Edition 2008 and either LV8.2.1 or 8.5
(3,009 Views)
(3,002 Views)
(3,000 Views)
Please post your project. Looking for errors regarding library calls is difficult without source code.
(2,980 Views)
Many thanks for looking at this for me.
In trying to come up with a isolating case, I discovered that the problem was that I wasn't copying the /data directory out of the /builds  and into the place where c++ was looking for it and so the dll was missing some vital support files.
(2,966 Views)
So that's the reason why I wasn't able to reproduce your problem.
It may sound strange but thank you for figuring out that a DLL lacking support files may fail silently.
I use DLLs quite often so I'm sure I'd have stumbled upon the problem someday. Smiley Happy
(2,960 Views)
