Problems with PCI-7811R after LabVIEW upgrade
Hi
I have been using a PCI-7811R under LabVIEW 8.2 for some time without difficulties. However, I have just upgraded to LabVIEW 2009 and it seems to have stopped working.
I tried to run some old code (that worked before) and I get the attached error. I try and locate the PCI-7811R in MAX ver. 4.7.7 and it's not there.
Any suggestions?
Gary
Message 1 of 17
(2,996 Views)
Just a guess- but a good oneSmiley Wink the DAQmx (8.9.5)or NI-RIO (3.5) driver that installed with LabVIEW 2009 (8.9.5) does not support the PCI 7811R.
"Should be" isn't "Is" -Jay
Message 2 of 17
(2,986 Views)
Thanks for that.
Assuming that you are correct, will it be possible for me to uninstall certain components and re-install older versions to deal with this problem? If so, which components should I uninstall and what are the latest version(s) that do support the 7811R?
Cheers,
Gary
Message 3 of 17
(2,968 Views)
Great question!
Poking through the read-me's for the various drivers left me without a clue.  Hopefully, your SSP is paid up and you can visit Here
That question would be better handled by a NI App engineer.   I could try shouting for one.  OH App Eng! Little help please.
Message 4 of 17
(2,963 Views)
Hi Gary,
I can let you know that minimum version of NI-RIO for the PCI-7811R is 1.3. all other releases after this are supported.
Minimum version of LabVIEW is 7.1, FPGA module is 1.1, LabVIEW Real-Time Module is 7.1.
This information can be found here: ftp://ftp.ni.com/pub/devzone/tut/crio_software_versions.htm
Has this answered your query?
Many thanks,
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
Message 5 of 17
(2,937 Views)
Thanks for the help. I uninstalled everything, then re-installed LabVIEW base and the old RIO driver 2.1.3 but to no avail.
If I uninstall everything again and then install LabVIEW base only, what is the minimum amount of other software/drivers thatI need to get the FPGA working again? Also which versions?
Cheers,
Gary
Message 6 of 17
(2,907 Views)
Did you also reinstall the LabVIEW FPGA module and the latest version of
NI-DAQ that supports the 7811?
"Gary7811" <x@no.email> wrote in message
news:1296137405378-1429798@exchange.ni.com...
> &nbsp;
> &nbsp;
> Cheers,
> Gary
Message 7 of 17
(2,894 Views)
I installed the FPGA module and an old version of DAQ. I'm not sure which the latest compatible version of DAQ is, so I installed an old version that worked previously. If you could tell me the latest versions of all the modules/drivers/etc that I need to get my 7811 working under LabVIEW 2009, that would be ideal.
Message 8 of 17
(2,881 Views)
Hi Gary,
From looking at this chart I can tell you that Daqmx 9.2.3 is the latest driver compatible with LabVIEW 2009. Besides that, the latest compatible NI-RIO driver can be found here.
This should get you up and running, I hope this has helped!
Many thanks,
John McLaughlin
Message 9 of 17
(2,875 Views)
Thanks for that. Just to confirm (as I only want to install ONE more time!), I should install the following in this order:
1) LabVIEW base
2) LabVIEW f3 patch that is recommended when I do the initial install
3) LabVIEW Service Pack 3
4) DAQmx 9.2.3
5) NI-RIO 3.5.1
6) FPGA Module
Will it be okay to install the version of the FPGA module from the LabVIEW 2009 CD pack?
Message 10 of 17
(2,868 Views)
