07-09-2015 02:41 PM
amr_attia wrote: (Private message, no need to private message)
My problem is to get the data out from the divice x and y readings . Can you help me
Here is the code and snippet. I had it from before. It reads Channel 1 and Channel 2 from the SR530, that is whatever the display is for Channel 1 & 2. You set the display manually or programmatically, I let you figure that part out.
Cheers,
mcduff
07-16-2015 08:39 AM
07-16-2015 08:41 AM
07-16-2015 10:16 AM
07-29-2015 10:14 AM
07-29-2015 10:19 AM
If you post the vi, I can take a look when I have time.
What is the difference between the display and the downloaded data exactly? What is the time constant of the lock-in?
Cheers,
mcduff
07-29-2015 10:33 AM
07-29-2015 11:24 AM
It sounds like there is a parsing error with the downloaded data. Without looking at the code, I cannot offer any suggestions.
Because you have the time constant set to 100 ms, there may be slight differences between what you see on the display and what is downloaded; it depends on the internal update rate in the lock-in.
cheers,
mcduff
10-07-2020 10:08 PM
Hope you are well.
I met the same problem as you mentioned. The MAX could find the address while the error code is always -1073807339 as I send the command. I did not get any value from both Channel 1 and Channel 2.
May I know the Labview version you used and "SW1:GPIB Mode Switches" and "SW2:RS232 Mode Switches" of your SR 530?
By the way, have you added a 270 pF capacitor in your SR 530 as suggested from Official website?
Shuen Wei
