Problems running an application with non NI DAQ cards
at the moment i try to write a program to aquire and send data with daq
cards. They were bought from Adlink. In this case i also got the
vi-library which uses the functions inside the driver dll.
If i run my created vi's inside LabVIEW, i have full access to all
installed cards an no error occurs. But after i use the application
builder and create a own application, i lost the access to the hardware
and nothing will be read or send.
Had anybody an idea what's going wrong?
Thnx
Henrik
(2,171 Views)
[posted and mailed]
h.skupin@web.de (Henrik Skupin) wrote in <3A31036B.F0641FC@web.de>:
>Hi,
You probably need to include the dll in the directory where the EXE is.
Alexander C. Le Dain, PhD
ICON Technologies Pty Ltd
http://www.icon-tech.com.au
* The LabVIEW FAQ http://www.icon-tech.com.au/thelabviewfaq.html *
(2,170 Views)
Hi Henrik, Sorry I am not giving to you an answer but a question. I found you were dealing with a non NI DAQ card and I am trying to do so, it is a self-made card with a MAX134 A/D converter designed to be plugged into an 16-bits ISA PC bus. I want to know How can I read/write from this board? That is How can I manage the ISA bus from LabView? Thanks in advance
Felix
(2,170 Views)
