I have a problem with an unitialized shift register and a cluster in cluster ( see simplified example)!
I can not select an element from the second cluster (for example "Test 2.b") and display it. This only happens when I use the "bundle by name" function first.
I have to use a workaround (see example)!
Can somebody explain this behaviour or is it a "bug" (and maybe already been fixed)?
I do not recall the details but in earlier versions of LV there was a problem with resolving like-named elements in sub-clusters. If your elements were a and b in one cluster and c and d in the other, it would probably work OK.
It is definitely a bug with LV7.1.1. I've seen this before. Only happens if you bundle first and then try to unbundle. You won't be able to select items after the first one in the unbundle function. If you move the unbundle operation to before the bundle, you can select whatever you want. My workaround was to unbundle everything I needed first, then bundle at the end. If I needed a new element that was just bundled, I would wire it from the source instead of unbundling again. In the next case, you can unbundle successfully. This bug is limited to one case at a time only.
