Problem with turning ON and OFF LED alternatively. Please guys I need your help!!!
I am using USB-TB-AI module. Please focus on the digital output in the block diagram. I have two loops. The top loop is basically configuration.
The bottom one is my main code. So when I'm trying to do is when I  turn ON RELAY 1, I want RELAY 2  to be OFF automatically. So when I turn RELAY 2 ON, I want RELAY 1 to be OFF automatically. I tried using case structure. It is not working for me. Please I need your help. (See attached VI. Please focus on Digital output or DO (D4-D5).
I am able to send signals, but I am not getting the expected results. What am I doing wrong? Please don't just do it for me? Just give me a brief explanation of what I am wrong that way I will not repeat the same mistake.
Note: Focus on the "Relay Test Main test" VI. The other VIs are just type def just in case you get a broken VI. For the relays to not have broken VI, save all these VIs in the same folder.
(170 Views)
Hi GRCK5000, your two loops are only connected by local variables. Even though your loops have the same delay, you cannot guarantee that every time a control is changed (via local variable), it will get sent to the instrument before it is changed again.
I would recommend using a single loop with some more states (such as "Update DO", "Read Thermocouples", etc.
Alternatively, if you need your top loop to run continuously, I would communicate between the loops using a queue. So when you need to update the DO you send a command packet telling it to do so. This is usually referred to as a "Queued Message Handler", and is what I would convert your top loop into.
(145 Views)
