Problem with report generation: incorrect VI icons
I'm working on a LabVIEW project (8.5.1) which includes a certain number of VIs (500). I have created a little LabVIEW application to produce automatically a HTML documentation of the project.
The problem I have, is that, from time to time the document contains bad icons but only for a few VIs and not always the same...
I had a look to ReportDocExtension.llb and found that the VI which is called Generate_pseudo_unique_filename.vi was a bit strange. I think that this VI, if it is called suficently rapidly could, from time to time, generate identical file names.
Has someone experienced the same problem? Is it a known bug?
Thank you by advance for your answer.
(1,086 Views)
known issues are listed on ni.com
hope this helps
Rodéric L
Certified LabVIEW Architect
(1,080 Views)
Accepted by topic author jihef
hope this helps
More precisely where can this be found on ni.com?
I think the problem I mentioned seems like a bug (still in LV2010). See attached VI which shows that the name generated by Generate_pseudo_unique_filename.vi is "pseudo unique" as suggested in the title but not unique as suggested in the comment..
So that, if you generate programatically a HTML report it is possible that you "loose" one .jpg file corresponding to a VI icon (typically the icon of VI n°1 can be named LVtemp0340086242585c.jpg and the icon of VI n°2 can have the same name). In this case, in the generated report, the icon of VI n°2 is correct but the icon of VI n°1 corresponds to the icon of VI n°2!
Now that I have found the origin of my problem, I'll set up a workaround.
(1,065 Views)
