Reply
Problem with my cRIO
I have some problems with my cRIO 9076,
I have this message in the MAX : see the picture
I think that I have all software intalled : see the picture
And when I create a project and add target device (cRIO) on my project, it like in this picture : see attached.
Thanks in advance.
(548 Views)
Hi
Excuse my ignorance, any chance the error code can be translated to English?
Jono
J Hobson
Certified LabVIEW Architect
(529 Views)
The cRIO is not on the same subnet as your PC.
The cRIO needs to have a IP in the same subnet as your PC is has.
(517 Views)
For inconsistent IP settings, refer to the following document: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6WdSAK. If after following those steps, consider installing the NI System Configuration 16.0.1 patch: http://www.ni.com/product-documentation/53420/en/.
(504 Views)
Highlighted
Thanks for your replies.
I try to change the IP adress of the cRIO, but I had this message :
"the target is locked. to edit these settings, click on login and enter the administrator password."
 the problem is that the login button is grayed. The screenshot is below
(497 Views)
Accepted by topic author Fred19ni
03-16-2018 07:40 AM
Change the IP Address on your computer to be on the same subnet of the cRIO.  You should then be able to log in and set the IP Address to whatever you want.  After the cRIO reboot, you can change your computer's IP settings back to what it was.
(490 Views)
