07-09-2020 09:41 AM
I am writing a state machine program. Suddenly the whole loop and case structure started to rescale when I try to move anything on the block diagram. If I select a terminal and press the arrow keys back and forth the structure just increases in size. How do I fix this?
Solved! Go to Solution.
07-09-2020 09:45 AM
07-10-2020 01:23 AM
I tried switching off autogrow, it didn't help. (Just switching it off made the case structure rescale...)
The block diagram is quite large, it fills the whole height and is about 1.5 times the width of my 1920x1080 monitor.
07-10-2020 01:31 AM
I found a solution.
I started to remove the last things I added and found a VI that caused the problem.
The block diagram started to behave as it should after removing and adding the VI again.
Thanks for the help!
