07-05-2006 07:00 AM
07-05-2006 07:35 AM
07-05-2006 07:40 AM
hi there,
are there several network adapters on your host? if so pass the IP of the network adapter to the "TCP listen.vi". i'm not sure but i think i remember that in former versions this had no effect. then you could use "TCP Listen.vi" on your slave and "TCP Open Connection" function on your host.
you can use the "Simple Data Server" and "Simple Data Client" examples for a quick test.
07-05-2006 07:55 AM
Hi and thanks for the help
You are right, paolo, the error is error1:
"LabView: the output parameter is not valid
NI-488: Command requires GPIB-controller to be active"
I am gonna try your suggestion, chrisger. Hopefully it works.
thanks
07-05-2006 09:23 AM
Hey buddies
thanks a million times. Now I got the solution thanks to Your suggestions. I just made a mistake. Accidentally i connected the wrong output of the TCP-listener-wait to the writer. Here the Connection ID-output is on the icon´s button. And I connected the TCP-listener-wait-Identifier to the writer. Stupid. I got to see that when I checked Your suggestions.
Thanks a lot
10-14-2018 09:01 PM
Hi, I know these isn´t the topic but, I need your help.
I'm trying to connect Epson Robot with Labview by Ethernet but I can´t do it. Can you helme? please. How can I do it?
10-15-2018 02:22 AM - edited 10-15-2018 02:23 AM
Start a new topic as this is not related to the original problem of this thread.
And please give a lot more information such as over what connection interface do you want to connect your robot with the computer, what software have you tried. You surely must have gotten some software with your robot that you can already use to control it?
Messages like yours with so little information to go with, will usually not get very useful answers and even less if attached to a really unrelated thread.
