Problem with Sparten 3E and Labview, ADC & DAC
I'm trying to use the ADC and DAC of the spartan 3E simultaneously. I used the examples for my first test but I have the big problem that I can only use ADC or the DAC. It must be a problem with the SPI communication.. Have anybody an idea what to do?
Many thanks in advance
Message Edited by chefweb on 05-26-2009 03:29 AM
(3,472 Views)
without having a closer look to your code I will try to give you a helping hand with the following links:
LabVIEW FPGA Module Training for Xilinx Spartan 3E XUP Hardware
http://zone.ni.com/devzone/cda/tut/p/id/6848
Simple SPI Communication to DAC and ADC IC using LabVIEW FPGA
http://zone.ni.com/devzone/cda/epd/p/id/2211
Getting Started with the LabVIEW FPGA Module and the Spartan-3E Starter Board
ftp://ftp.ni.com/evaluation/academic/getting_started_spartan.pdf
Also the IPNet Link will help you out with further problems:
http://zone.ni.com/devzone/cda/tut/p/id/4799
Please let me know if this could solve your problem.
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(3,446 Views)
