I have some problems installing Labview in my linux mechine and I found this add.
Ok,
First, my system is running Ubuntu 7.04 feisty. I'm try to install LV 7.0 express for linux.
During installation I experience some problems with permissions so I suspended twice or three times and continue, as result some of the installed packeges were on a personal folder on /home/../LV70 and the other part on /usr/local/LV70 (default)
I try to run the application and crashes on start. Then I decided to start all over and I errase the thing on my personal folder trying to use the original "by default" options. Result.....the installer said that everything is alrready installed, and does not allow me to re-install. I want to get rid of all the things created on the first install and do it again....were is the log file that tells the installer taht everithing is on my computer? there is a way to modify the log? there is a way to re-install?
S.
