Problem in resizing multicolumn listbox in
@ramktamu wrote:
Hello Ranjeet,
What you have to do is 'disable the horizontal scroll bar' in a visible menu. The multicolumn listbox will automatically fit the columns.
Ram Gurung
Certified LabVIEW Developer
That is not true.  Where did you get that piece of information from?
You can even see in Ranjeet's picture that he has the horziontal scrollbar disable and the list box did not "automatically fit the columns."
Ranjeet, I don't think you need to have two different .exe's.  I don't know why you'd want 3 columns on one PC, and 4 on another (why can you get rid of the extra column on one PC?).  But you can certainly handle the number of columns to show and their width programmatically in a single VI.
Message 11 of 20
(701 Views)
@ramktamu wrote:
Hello Ranjeet,
Ram Gurung
When I disabled then only 3 col is visible unfortunately Smiley Very Happy Smiley Very Happy Smiley Wink
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 12 of 20
(694 Views)
I want 4 col all the time irrespective of monitor,  Supposed I do this then each time when user opens the VI then he need to set this option which I will be providing. I dont want to give any this options to user .
My concern was only when all other things were resized then why not this?
--Ranjeet
Message 13 of 20
(691 Views)
Is this their propery like font which also doesnt resize according to monitor
--Ranjeet
Message 14 of 20
(680 Views)
Because the programmers who made LabVIEW never programmed it to do this.
And I'm not sure that I would want them to.  I don't know what would be considered normal behavior for table type controls within other programs, whether something like VisualBasic.  I'd say Microsoft Access and Excel aren't resizing columns based on the window size.  My gut feel is that the behavior you want is probably atypical of most programs out there with similar type of an interface.
Message 15 of 20
(669 Views)
@Viper wrote:
See the attached vi
Norm
I know how to set programmatically set number of column. I need fix 4 column but my problem is in devlopment PC its perfect and in other PC 4th column is partially visible
Are you using the property node? If not I think it will solve your problem. I have this problem all the time because I develope on Win7 and roll out to Win XP.
Message 16 of 20
(662 Views)
I am also rolling back from 7 to XP. Let me keep 4 programmatically and check again. Thanks
--Ranjeet
Message 17 of 20
(648 Views)
Still didnt worked Smiley Sad
--Ranjeet
Message 18 of 20
(644 Views)
Why are you still asking about this? Well actually making vague comments and not asking anything. You have been told to use property nodes. This is your answer.
Message 19 of 20
(637 Views)
If you don't want to resize the listbox programmatically the simple solution would be to uncheck set VI to resize per monitor resolution. The proportion of the interface would change but everything will show up.
Ben64
The best way to say thanks is to give kudos!
Message 20 of 20
(633 Views)
