07-31-2010 02:13 PM
I developed the labVIEW project for power plant. And I created the exe file of this project. But this exe indicate the main front panel window with all sub VIs front panel & control panel windows. Display the main window only. When I need sub windows that time only display the sub VI windows. But program is not a problem my EXE only the problem.
i want Anybody’s help me my id prabhubala.kg@gmail.com
08-01-2010 06:56 AM
Hi Prabhi.KG
I can't be 100% sure, but this sounds like you remove the front panels from your subVIs. When you build an EXE the default setting is to remove the front panel and block diagram from the included subVIs. You can change this setting on a per file basis under the "Source File Settings" in the properties of your Build Specification.
Best Regards
David
NISW
08-02-2010 04:11 AM
