Problem facing in tab control with blinking property of other control..
Can ay one help me??
I am sending one vi, in that i face one problem with tab control. If i am put a multicolumn list box on page1 of tab control and apply blinking property on it than in run time the blinking can visible on all the pages of tab control. It shouldn't be like that. The blinking can only visible on Page1. Is it bug in Labview? or it is like that only? how to solv it?
Greeting from India,
Malhar
(2,952 Views)
Well, it seems that LabVIEW does not work correctly here.
So a little workaround:
You can detect changes in the tab-selection by using the event structure. So you can disable the blinking property of the table when leaving the tab. Please see attached example.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,949 Views)
Thanks for your reply,
But I am using Labview 8.2 and cant open ur vi because ur vi is made with the help of Labview 8.6, so can u send me ur vi in Labview 8.2 competible.
Malhar
(2,934 Views)
Well, i hope this works for you:
Norbert
Norbert
Expert: Geometry
(2,932 Views)
Accepted by Malhar
thanks for your support
Malhar
Malhar
(2,917 Views)
