Problem communicating with a Chroma LCR Meter using VISA
Highlighted
Thank you very much for the detailed explanation. It all makes sense now.
Message 11 of 13
(67 Views)
Highlighted
For completeness and to share with others I have attached a screenshot of the solution which works a treat.
Thanks again for all the help.
Message 12 of 13
(65 Views)
Highlighted
I recommend doing one thing.
Go to the string constant, right click, Visible Items >> Display Style.
When you use a non-normal display like \codes, it helps to show the display style for the reasons I mentioned in my previous post.  It let's you see at a glance in the future, that the \n in there is a linefeed character and not a backslash "n".  With that display indicator, it is ambiguous looking at a picture of your code whether you set that constant correctly or not.
It is also a good idea to do it for string constants set to hex display.  And any numeric constants that aren't set for decimal display.
Message 13 of 13
(58 Views)
