Problem communicating with E4980 LCR meter
I am really new to LabVIEW and I am using a VI written for HP4263A LCR meter. I replaced two sub vis of reading measurement and Configure and used vis from E4980 library. Before connecting to the LCR meter, I don't see any error on the Vi. However, when I connect it to the LCR meter, the Vi is not working properly and it is only showing 0 for the resistivity. I would appreciate if you could please help me.
(2,469 Views)
Hi Niloofar,
have you even tried to debug your VI? Did you used some probes or highlight execution?
Then you would have recognized the origin of that error!
Hint: it's not in those E4980 subVIs…
(2,406 Views)
Hi GerdW,
Thank you so much. I used highlight execution and the problem was with DAQ assistant.
Niloofar
(2,380 Views)
