Hi Zamzam,
with the following example, you can learn how to make some controls into the cursor palette invisible.
Please note that number 6 hides the numeric indicator for the Y coordinate; if you want to hide the X indicator, change it to number 5.
To use this code into your program, copy and paste the example block diagram, leaving out the graph control and the Array reference, then create your own Array reference by selecting the Cursor Palette (only this object!), right clicking and selecting Create->Reference.
(before saving changes and running the vi, make a backup copy of your original vi, because you may not be satisfied with the results!)
Paolo
Paolo
