08-24-2011 04:23 AM - edited 08-24-2011 04:24 AM
OK, may be missing something here but...
I have a very simple subVI that i call on several occasions and is used in several projects. The subVI is a couple of years old, and has worked well.
Now the SubVI appears not to run. But it does not show any errors.
If i open the block diagram i cannot use the 'probe' or 'stop point' tools, if i click, they will not put a probe on a wire etc.
If i cut and paste the BD to a new, blank VI i can use the tools on the new VI.
I am about to assume this means the original VI is corrupted...?
XP, full SPs Updates etc
LV 10.1 -current
08-24-2011 07:37 AM
I think your VI has "Allow debugging" set to false. You'll find this option in the VI properties > Execution.
08-24-2011 07:57 AM
Or it is re-entrant and LV does not which instance you are looking at.
Ben
08-24-2011 09:40 AM
Thanks for the sugestions.
dan_u,
Yes indeed... i should have spotted it. This solved the probe problem.
Ben,
The subVI is re-entrant i tried the instance on the caller VI BD, and the 'master' via the Project Explorer window.
I could not get to the bottom of why the subVI did not run correctly. A restart solved the problem, which i guess i should have tried earlier.
08-24-2011 09:52 AM
I have seen a bug in LV RT :: when probing arrays in a VI running under RT, the probes where empty (if arrays) or bogus.
I reported it to NI and they said the work-around was to reboot the RT machine.
Ben
01-23-2012 02:58 PM
Somehow I disabled the debugger function. I was having a hard time. Your message was the answer. Thanks for posting the answer.
Philip
07-03-2013 06:15 AM - edited 07-03-2013 06:18 AM
Enable the Allow Debugging check box in VI Properties,for the probe tool to work
