Hi Greg,
Thanks for the info. That should do the job, but I'm still a little
disappointed that LabVIEW can't do something as simple as printing a
waveform or graph without doing heaps of modifications to the graph (and
placing it in another VI). Do you know if there's a way of getting rid of
the header information which is printed at the top of the page? We're
planning on producing a product which we want to look professional, and that
header info tends to make it look pretty amateur.
Thanks again.
Shane Broadbent
shaneb@cfcl.com.au
"Greg McKaskle" wrote in message
news:3B39D085.AF192C51@austin.rr.com...
> > Thanks for your response. Unfortunately using this method will still
print
> > the graph
out as a bitmap image. I'm after something which will provide
a
> > better result like you would achieve from printing a graph within Excel.
Do
> > you have any other suggestions?
> This will print the graph using whatever printing style is selected in the
> Tools>>Options dialog. The printing page gives you access to three styles
> of printing -- bitmap, standard GDI, and postscript. The default is to
send
> the drawing commands, lines and such straight to the printer much like
vector
> graphic. Postscript often looks the nicest, but only works if you have a
> postscript printer, and bitmap printing actually increases the resolution
> of the bitmap to take advantage of the printer, rather than using screen
> resolution.
> Greg McKaskle
