Is it possible to use a concatenate string to print to the Zebra TLP 2844 label printer? I have set up my templates using ELP in a constant and they print off fine but now I need to be able to allow the user to enter information each time the program is run. I have split the code up into a concatenate strings and added controls but now the label won't print. I have checked the ELP code and it seems fine. Do I need to add a line feed constant after ever line after my control "? Any ideas are much appreciated.
EPL is picky about the end of lines. I would make sure that you are terminating each command line with a line feed. It will ignore the carriage return if it is included. The important part is that each command must be on its own line.
Mark Yedinak Certified LabVIEW Architect LabVIEW Champion
"Does anyone know where the love of God goes when the waves turn the minutes to hours?" Wreck of the Edmund Fitzgerald - Gordon Lightfoot
