Print front panel by clicking on a boolean button
Hi everyone,
I need that a user can print the front panel just by clicking on a button in the front panel.
Apparently I need to use Report generation ==> Easy print VI panel + a boolean button.
But I have no idea how to make the connections. My code is in a while loop. Where I have to connect the inputs "VI path" or "contents" for example and then how to connect the boolean button ? (I just want to print the front panel)
(I have seen the manuel help on ni.com but it didn't really help me...)
Thanks for your help 🙂
Best regards
(2,757 Views)
Accepted by topic author Elohim
You just need to wire a Current VI's path to the Easy print VI panel (VI path input). And that's it. It will print the VI front panel on the default printer.
If you can't use the event structure just place a case structure and wire your Print button to the selector. First make it print on the default printer with default settings and then start to play with things such as contents.
(2,750 Views)
Thank you !
It really helps me (it lacked me the information about the current VI's path to progress more). It should work now.
Regards 🙂
(2,738 Views)
