02-23-2006 04:32 PM
02-23-2006 04:40 PM
Are you using the "Print.VI To HTML" method of the VI Class in VI Server? If so, the help for this method indicates that this method is not supported in the Run-Time System, i.e. not supported in a built executable.
-D
02-24-2006 08:42 AM
02-24-2006 11:05 AM
You can use the Report Generation VIs to generate the HTML report. Specifically, you could use Append Front Panel Image to Report.vi and Save Report to File.vi to save the image of the panel to an HTML report.
Check out the examples in examples\reports to get a better idea how to use these VIs if you've never used them before.
Good luck,
-D
