Pressure transducer labview setup
For the following circuit, assuming the pressure transducer is a 1-6v output with a psi rating of 100. how could i design a data aquisition system to display the pressure  in psi.
i have roughly built the circuit to out put voltage at Vab = 1V when there is 0 pressure, or 0 resistance at the potentiometer
and vab = 6V when there is 1000ohm resistance from transduce or 100 psi.
new to labview would like some assistance in setting up this system
(4,287 Views)
If you have a pressure transducer with a 1-6 V output, why do you want or need a resistive bridge?  Just measure the votlage.  There are many DAQ devices which can measure 1-6 V.
I find it unlikely that the pressure transducer has 0 resistance at zero pressure.  So is it a resistive output transducer or a voltage output transducer?  Please indicate the manufacturer and model of the transducer.
What version of LabVIEW and what DAQ devices do you have?
Lynn
(4,284 Views)
Hii
Is this about a Strain measurement ? if it is you may want to refer this
https://www.ni.com/en/shop/data-acquisition/sensor-fundamentals/measuring-strain-with-strain-gages.h...
You can check NI DAQ modules for Strain Gauge here : https://www.ni.com/en-us/shop/model/ni-9236.html
Is this for Academic purpose or you are actully making one ? If you are thinking to build one, there are some serious factors and formulas (other than R1/R2 = R3/R4) that needs to be considered.
You might want to chekc Vishay.com for further details on this.
Let me know if you have anymore questions.
Kudos are welcomed Smiley Wink
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
(4,280 Views)
its a question from a text book i am refering to, so i guess it would be a resistive output transducer, connected to the bridge to give a voltage output. wondering what the block diagram would look like for such a thing. There is no specified model number to the transducer.
(4,276 Views)
1. Define your inputs,
2. Define desired output,
3. Find a Mathematical Relation between them
4. Program the Math part.
Kudos are Welcomes Smiley Wink
Thanks & Regards,
Kunal Raithatha.
more reply back.
(4,272 Views)
