Pressure Transmitter Recomendation
I an in search of a pressure transmitter in which I can
set the input range (resolution) via serial port using LabView.
Possibly sending a string to the transmitter to tell it what
range so as to get the best resolution as possible.
The application is that I need to measure pressures that can
range from say 1 to 2 psig upto 400-500 psig.
I would like to be able to set the range of the transmitter to
say 0-10,0-100 or 0-500 based on an initial pressure reading.
Any recomendations would be appreciated.
Dan Caragher
Dan_Caragher@pall.com
dcaragh1@twcny.rr.com
(1,300 Views)
Hi Dan,
Assuming that you are looking for a pressure transducer (I'm not familiar with "transmitter" name), I'll suggest PX971 from Omega. It's a piece of equipment and it seems to be exactly what you are looking for.
You can find a short description here [http://www.omega.com/ppt/pptsc.asp?ref=PX971&Nav=prew01] or complete specs [http://www.omega.com/Pressure/pdf/PX971.pdf].
Anyway, take a look to their entire presure related product line.
Hope this helps.
(1,300 Views)
I forgot to mention about ranges ... I'm not sure if you can choose them but anyway, the precision is quite good.
Good Luck!
(1,300 Views)
