11-05-2018 11:52 PM
Hello Everyone,
All you are doing good. I am using the maxi gauge TPG366 with gauge sensor and try to get the actual value but it giving the approximate value.
I am sharing the code and picture so you can guide me after checking the where is the mistake. Waiting for your prompt and result oriented response.
I am using the example read pressure.vi file to measuring the pressure.
Thanks in advance
Taufeey
11-06-2018 12:56 AM
Hi Taufeey,
somewhere somewhen someone did implement an explicit function to convert all points in the received string data by commas. Maybe because of using wrong regional settings on its computer…
(Hint: see the function "PV ActiveLine - Point2Terminator.vi")
Can you please show the content of a typical received string from your device?
I guess the main problem is the function "PV ActiveLine - Convert Data.vi": run your VI until there are data in the controls/indicators of that VI: then stop your program, set all values default in this VI and save it. Then attach that VI here for examination…
(IMHO that whole lvlib is a pure mess, it should be cleaned up and/or redone.)
