Press button hidden by image
How can I use a button that is laying under an image?
(1,132 Views)
Make the button transparent and put it in front of the image.
Lynn
(1,127 Views)
Hi Jo,
you can't unless you move the button on top of that image...
Maybe you should explain what you gonna do?
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
(1,126 Views)
... or, you could respond to a click event on the image (I'm assuming you're using a picture indicator), get the coordinates, find out if they're within the rectangle of the button, and then trigger the button's click event.
Sounds to me like Lynn's suggestion is far easier.
(1,119 Views)
... or you can also customize a button with your image. Even having two images depending if button is pressed or not.
Olivier L. | Certified LabVIEW Developer
(1,106 Views)
I try the transparent button. Tnx!
(1,095 Views)
