04-06-2012 02:30 AM
Hi Everyone,
Is there any possibility to duplicate Y scale in waveform graph @ run time (progrmatically). Kindly let me know if anyone knows.
Thanks in advance!!!...
04-06-2012 03:28 AM
Am not sure whether you will be able to duplicate Y scale during run time but one more suggestion you can create many Y scales in the edit mode and make it visible whenever it is needed.
Good luck
04-06-2012 08:48 AM
04-10-2012 09:07 AM
Thanks for your response..
I saw the attached link. It says that there is 'Duplicate scale' method, using that we could duplicate Y scale for waveform graph in runtime. But could you please tell me which version of LabVIEW this method is available. Because i searched in LV 2010 and i was not able to find.
Kindly find the attachment which is taken from LV 2010 environment.
04-10-2012 09:15 AM
I don't think it is implemented till now because I am using LV 2011 but I don't see any option for scale duplication.
04-10-2012 09:52 AM
There is no such method, even in the currently shipping version of LabVIEW. The idea is a suggestion to add that method. The picture you see in the Idea Exchange is a mockup of what the suggested method should look like. You currently cannot programmatically duplicate scales. Sorry.
