Powering an electromechanical relay with an NI-9481 module.
 I am trying to use an NI-9481 on an NI cDAQ-9172 to generate a digital output voltage to power an electromechanical relay. I can manage to switch the different channels of the NI-9481 on and off; however, the electromechanical relay I am attempting to power refuses to turn on. Is it truly possible to generate a voltage using the digital output on the NI-9481? If so, what logic would I use for labVIEW 8.0 to create this voltage? Thanks in advance for any help with my problem.
Nick
Message 1 of 32
(6,377 Views)
It sounds like you are only asking part of the question.
To pick a relay requires work so the question is "Does the output provide enough power?"
Power (in DC) is current X Voltage.
Add to that
current = voltage / resistance
and you should be able to check the spec on your relay and the DO lines and answer this Q.
Ben
Message 2 of 32
(6,371 Views)
Nick,
It looks like the 9481 is a SPST relay device - it will not generate a voltage to turn on your external relay.  You can use the 9481 to switch on power for an external device.  Look at page 8 & 9 of the 9481 spec (http://www.ni.com/pdf/manuals/373507c.pdf).
-cb
Message 3 of 32
(6,368 Views)
Thanks for the help. I found an external power supply and solved my problem. Now I have a few more questions.
First, can I output a voltage with the NI-9205 module running on the same cDAQ? If so, how?
Second, what labVIEW logic would I use to fire three of the four channels in my NI-9481 relay in a given sequence as input by the user? (Example: Channel 1 cycles on for 8 minutes, switches off for a day and a half, then channel 2 cycles on for eight minutes, then switches off, then channel 3 cycles on immediately for 2 minutes, then switches off.)
Message 4 of 32
(6,356 Views)
To program your relay sequence, use a State Machine with any of the several Timer functions. Personally, I like to use the Event Structure with the state machine inside the Timeout event.
I'll see if I can whip up a quick example.
B-)
Message 5 of 32
(6,346 Views)
This should give you a general idea of using a state diagram and event structure to control your sequence. I don't have the code to communicate with your NI-9481 module, but you can get the general idea.
I based it on the following default sequence: (I used seconds for testing instead of minutes or days, of course)
Initialize - All Relays OFF
(User Presses Start)
Cycle 1 - Relay 1 ON - 8 Seconds
Cycle 2 - All Relays OFF - 30 Seconds
Cycle 3 - Relay 2 ON - 8 seconds
Cycle 4 - Relay 3 ON - 2 seconds
Stop- All Relays OFF - Until Start
Hope this helps!
B-)
Message 6 of 32
(6,328 Views)
Thanks for the fast response. Is there any way to convert this example vi to use in labVIEW 8.0?
Message 7 of 32
(6,324 Views)
Sorry about that. The previous version was in 8.2. These should be 8.0.
B-)
Message 8 of 32
(6,319 Views)
Hi everyone,
LabViewGuruWannabe, it’s great to see such clean and organized code!
nick525, you will not be able to generate a voltage from the 9205 in cDAQ. The DO0 line is only available for use with cRIO. The KnowledgeBase Article: Using the Digital Output and PFI Lines of the 9205/6 with Compact DAQ explains the difference of functionality of the 9205 in cDAQ versus cRIO.
Please post back if you have any questions. Have a great day!
Ryan D.
District Sales Manager for Boston & Northern New England
Message 9 of 32
(6,291 Views)
Thanks for all of the help guys, I really appreciate it, especially with the state machine. It's such a useful tool in labVIEW and I really had no idea how to use one. Thanks again!
Message 10 of 32
(6,284 Views)
