Please check the following link for the
OPC driver list that the IA OPC server has.
If there is none, then you could get the drivers for the manufacturer and add them to the OPC server. If it works with MODBUS, then try using the Modbus driver, just make sure that you map the memory addresses to the best fit. Another option is to use the OPC server of the manufacturer.
Hope this helps.
Ricardo S.
National Instruments.
