11-17-2006 12:57 PM
11-17-2006 01:09 PM
I am hot on the trail of LV 8.2 DSC bugs and I have not seen or heard about anything like what you described.
Could you please post some code that demonstrates the behaviour?
Ben
11-17-2006 01:23 PM
11-17-2006 01:45 PM
I just tested the valve booleans i use in my application and they work fine for me.
If you copy the boolean in question to a new VI and remove its binding to the shared variable, THEN run continuous the new VI (phew),
does it work correctly?
If so, I suspect a race condition.
One way or another, to get a bug fixed we have to give NI an example that demonstrate the issue.
Try throwing away parts of your VI until you have simplified the code as much as possible and then use the "Attachment" option (its below the "Submit Post" button) to post your example.
Trying to help,
Ben
11-17-2006 03:35 PM
11-18-2006 11:04 AM
