Possible to use stand-alone as subVI
I would like to turn all the DAQmx and DAQ Assistant VIs into executables (on a PC), so they can be called as subVIs when building another VI on a Mac, since they do not work directly on a Mac.  Is this possible?
Thank you.
(2,353 Views)
Quite simply, no. No executable built on a pc will run on a different OS and even if they did, you would still need the DAQmx driver to run them.
(2,344 Views)
