02-11-2010 09:05 AM
I would like to give the user the option to select and modify/delete certain rows in an array -I'm displaying it in an indicator-
It's a 2D array. Is this possible? Also I was wondering if it is possible to highlight certain rows programmatically.
02-11-2010 09:19 AM
You cannot modify data in an indicator using the front panel while the VI is running, regardless of the datatype. You need a control.
I would suggest looking into using a table or a multicolumn listbox. Those provide capabilities for highlighting cells.
02-11-2010 09:31 AM - edited 02-11-2010 09:34 AM
You can use the array pallete to accomplish the task.
i have the attached avi for reference.
as for the highlight above sugestion will be good
Shrek
02-11-2010 09:35 AM
02-12-2010 03:15 AM - edited 02-12-2010 03:15 AM
Hi _Faust,
As smercurio already told you, you can use a Multi Column Listbox or a Table to do the "trick".
As an example, I've just created a VI which is based on a Table, where you can remove the selected row by clicking on a row and pressing the "Delete Row" button.
I hope this will help you to create the program you need.
Peter S
