Possible to force client disconnect/timeout in web publishing?
I'm trying to make an application that would publish embedded vi to be accessed by web browser clients across the network.
The problem I run into is that when one client loads the page, connections other clients are prevented, due to Labview license limitations, with is OK with me if I could force the 1st client to disconnect after a set time or stage of the VI execution.
I tried changing client time out settings in the application config file, but it has no effect - a client stays connected forever until client web page is closed.
Is there any other way to address it?
(2,711 Views)
Hi Fedor,
Check out this KB. It should be exactly what you're looking for!
Thank you for choosing National Instruments.
Aaron P
http://www.ni.com/support
(2,677 Views)
