Hi Craig,
I'm working on the same issue wanting voltage sweep as 0v>-5v>0v>5v>0v. I was trying to work with the voltage loop by adding the absolute value but didn't work. If you have solved the problem, would you pls post the block panel or code?
Thank you! Much appreciated!!
Tina
