Position of For Loop
I have auto indexed a For Loop (See attached .vi).
I would like to show the position of the For Loop on the front panel. At the moment the position is only shown at the end of each iteration of a loop. I would like to show the iteration of the loop (ie 1 - 6) at the beginning of each loop. How do I do this please?
(3,317 Views)
Hi Nevica,
Using 'Flat Sequence Structure' you can meet your requirement. here in first sequence show the position of the for loop and in second sequence you can do your application part. I think this will help you to achive your requirement.
(3,306 Views)
Accepted by nevica
R-click incoming int-wire in loop and create indicator.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,297 Views)
You don't need an auto-indexing For Loop if all you're going to do is operate on a sequence of numbers.  Tell the loop to operate a fixed number of times (in your example, six) and use the Loop Iteration terminal with an Increment node.
Jim
(3,274 Views)
To quote from LabVIEW help, " The iteration (i) terminal provides the current loop iteration count, which ranges from 0 to n-1."
(3,262 Views)
