04-26-2018 08:26 AM
I need to parse a string to recover some info from it, the string contains geometrical properties of a drilling tool written as a series of five numerical values and a name, for example:
"0, 0.250, 20.000, 0, 0, Con20°_0.25mm"
I did something like this:
and it works:
The problem is that when I use this code with the same example string from another computer it doesn't, both computers have the same version of labview (2017 32 bit), how is it possible?
04-26-2018 08:32 AM
Hi Antares,
Have you checked taht both computers use the same Regional and Language options ?
Maybe one is using a '.' (point) as decimal separator whereas the other one uses a ',' (comma).
04-26-2018 08:43 AM
I agree with Maxime on a possible cause. If you read the Help for this function, you will see that you can set/override the decimal separator by using what LabVIEW calls the "localization code syntax elements".
Are you not parsing at all that last quantity (Con20°_0.25mm)? You could pull out the "20" part and the 0.25mm part as two more values (or just the 0.25, as you wish).
04-26-2018 09:18 AM - edited 04-26-2018 09:21 AM
Actually they use different configuration for '.' (dot) and ',' (comma).
I tried to set it up properly but it is still not working, I tried from the control panel on windows but probably there is something on labview option panel, can it be?
No it's ok like this because it is just a name, and the values inside (for example 20 or 0.25) can still be recovered from the numeric array
04-26-2018 09:39 AM
I tried with Tools/options, disable "use localized decimal point".
Now it's working!
Thank you
04-26-2018 09:42 AM - edited 04-26-2018 09:43 AM
I'm not sure the solution you found is the ideal one. When the VI is compiled to an exe or used on a different system this setting might be lost.
Just prepending %.; in front of the format string (this will force the use of . as decimal point) seems the better option.
04-26-2018 01:21 PM
dan_u is correct. You really should just set your format string to be:
%.;%f,%f,%f,%f,%f
The %.; forces the format to use the period as the decimal separator. And just for completeness, you can use %,; to use comma as the decimal separator.
04-30-2018 02:58 PM
Perfect, thank you all!
