08-28-2018 12:51 AM
Hello, I have got an interesting issue with the PopupMenus creation.
I want to have the cluster allignment options not like the PIC1.png, but like PIC2.png.
With the attached lib copied to "LV/resource/plugins/PopupMenus/edit time panel and diagram" folder it is achievable, but the functionality is not good.
I think the issue can be with the type cluster, but i don't know why. With another data type as Array, this approach is working.
Any idea where could be the problem?
Thank you.
08-28-2018 01:17 AM - edited 08-28-2018 01:17 AM
Hi Tibor,
Can you define the problem with more details?
What exactly is "not good"?
Btw. please don't attach BMP files with just renamed file suffix. Convert them to real PNG images! Do you see the difference in filesize?
08-28-2018 01:48 AM
Dear GerdW,
I guess that problem is that it does not work as expected - I've tried, and menu appears, but selection "Arrange Horizontally"/"Size to fit", etc. does not change cluster view...
08-28-2018 04:47 AM
Hi GerdW, thank you for the picture hint.
The problem is that the menu appears one level up, that's good, but after choosing cluster align option the cluster remains the same.
If "Size to fit" is clicked, it should fit the cluster according to it's elements, but it doesn't.
