Popup to select a directory - how?
i am using Labview 2013. Is there meanwhile a included solution for a popup where user can select a path (not a file)?
(I found an old thread where an extra external vi was needed to do this)
Can it be done with labiew tools?
Thx
Edit: Solved: Can be easy changed in browse-options
(2,792 Views)
Using a file path control, change the Browse Options (under Properties) to be Folders instead of Files.  This will allow the user to select a folder path instead of a file.
(2,772 Views)
