Poblem with graph in labview for TDS3000
I'm using the Tektronix TDS3000 Labview driver to setup a TDS3012C  oscilloscope and am looking to measure Voltage Graph on channel 1 and Current graph in channel 2. But when i using channel 2 to do some demo and try to put off channel 1, Graph in Channel 2 did not display.
Here i attached some files for your understanding about my problem. M.word and  my vi
thanks
(4,834 Views)
Are you getting any errors?  You should really put your Error Out inside of the while loop so that you can watch for an error.  I'm thinking you are getting an error when you try to take the measurement on channel 1.
(4,810 Views)
Thanks for the reply
So far i run this program no error came out. but maybe i will put the 'Error Out' inside the while loop and try again with the oscope.
Crossrulz. do you see any problem in my programming?
(4,799 Views)
You are currently not getting any errors out because you are overwriting the error tunnel each iteration and the Exit state doesn't pass on any errors.  So you really need to rethink your error handling.
Other than that, it looks fine to me.
(4,788 Views)
Hello and good day
I have put my 'ERROR OUT' inside the loop. as you recommended. and it came out as attacment entitled ' MY PROGRAMMING'. It works well when i connected it in channel 1 in the scope. and it seems problem when i connected to channel 2.
Other than that, I also run the example( AUTO SETUP WAVEFORM)  that i downloaded from the NI for the TDS3000, seems like the example give me an error too as in attachment 2.
(4,762 Views)
Waveform requested is not turned on.  It might be time to turn on that highlight execution to figure out exactly where that error is happening.  It will make things a lot easier to diagnose from there.
(4,742 Views)
thanks for reply
where can i see the highlighted error. it only came out to the 'ERROR OUT' box and not in the block diagram
What about the programming from the NI? I'm not sure either i'm doing it right or wrong, anyhow i didn't modify the coding
(4,730 Views)
