Plz I need help,can some one kind help me ,What is a DAQ assistant
I dont have any DAq hard ware, still i want to use DAQ assistant,Plz guide me what it is ?
How it is configured for input and output channels?
(3,289 Views)
DAQ assistant is a wizard in LabVIEW that enables you to setup a simple Data Acquisition System given that you have a DAQ-device.
Without any hardware it's useless.
Ton
My LabVIEW Ideas
(3,278 Views)
I would suggest doing some reading: Getting Started with NI-DAQmx: Main Page.
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(3,262 Views)
Why do you want to use the DAQ assistant if you do not have any hardware?
It is possible to use MAX to simulate a device which you should then be able to select in the DAQ assistant
David
www.controlsoftwaresolutions.com
(3,238 Views)
